586,123 active members*
3,433 visitors online*
Results 1 to 2 of 2
    May 2009
    16
    30'-50' cable ok to use?
    I want to relocate my computer and would need to run a much longer cable to my mill (Syill X4 Plus). Can I run a 30' cable from my computer running Mach 3 to the mill? I got paranoid about the signal qulaity/strength.
    Jan 2010
    2141
    If you're talking about a 25-pin parallel port cable between the computer's LPT port and a breakout board (ahead of the motor drivers), I would be surprised if you could do such a thing and get reliable operation. But I have never tried such a thing, so maybe someone else will chime in and tell you that it is possible with a special cable.
    They do sell high-quality 25-foot LPT port printer extension cables, and so perhaps you could get a similar, straight-through 25-pin cable in such a length, but I would want to check the signal waveforms at the end of such a cable with an oscilloscope (for pulse shape, amplitude, and delay) before trying it with an actual CNC cut, and even then I would be concerned about reliability. I personally would not be comfortable with using a parallel port cable that was any longer than about ten feet.
    Maybe someone makes special-purpose optical cables that could be pressed into service over such distances, but I have no information about or experience with such things.
  1. AC power cable in the same cable carrier with motor cables
    By bandtank in forum CNC Machine Related Electronics
    Last Post: 06-02-2010, 12:06 AM
  2. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
  3. without using a cable
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-26-2008, 08:46 AM
  4. USB Cable
    By HillBilly in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2008, 08:39 PM
  5. cable
    By lgalla in forum Stepper Motors / Drives
    Last Post: 02-10-2007, 04:55 PM
