586,070 active members*
3,467 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Convert from Metric to Imperial
    Apr 2010
    I have a DXF file that is setup in MM that I would need to convert to Inches so I can run the part correctly. Having a bit of trouble doing this. Is there an easy way to convert the drawings that are created from the DXF into Inches?
    Thanks!
    May 2010
    307
    Is it a drawing or a sketch? I'm assuming a sketch.
    You can scale a sketch by the appropriate scale factor and then change the units of the part file.
    Apr 2010
    Its a sketch when I open it in SW I import as a new part too 2D sketch. Then under the drop down menu for Units of imported data I select Mils and click finish.
    This brings it in with MM's however the document is in IPS when I go to options> document properties>units of measurement. Also when I smart dimension a section of the sketch it shows up as mils in the pop up box but in the properties manager is shows inches.
  1. Metric vs Imperial collets
    By JulianDR in forum CNC Tooling
    Last Post: 11-23-2010, 04:03 PM
  2. First Machine, EU, Metric or Imperial?
    By daithi in forum Mini Lathe
    Last Post: 02-24-2009, 09:00 PM
  3. Change from metric to imperial
    By cijunet in forum Mastercam
    Last Post: 12-10-2007, 06:51 AM
  4. Converting from metric to imperial
    By Pharkas in forum Mastercam
    Last Post: 05-04-2007, 04:46 PM
  5. Metric mm or Imperial inches? Please help.
    By alexccmeister in forum Benchtop Machines
    Last Post: 02-22-2007, 03:19 AM
