586,103 active members*
3,599 visitors online*
    Dec 2006
    22
    DB connector cutouts
    Hi all,
    I need to make some cutouts in a backpanel for some standard DB connectors (DB-9, DB-15, and DB-25). Does anyone know where I can get some accurate drawings of the outlines and mounting holes that I can import into my drawing? I can use DXF format, but anything that can be imported into Rhino or MoI will be fine.
    Mark
    Jan 2009
    334
    DB-25 Panel Mount Plate
    Quote Originally Posted by mickelsen View Post
    Hi all,
    Mark
    Mickelsen, check the link below for DB-25.dxf connector;
    Highly Liquid: MIDI Accessories: DB-25 Panel Plate
    Check this link for cutouts database;
    Purcell Brackets;Brackets:PCI brackets, i/o brackets, compact PCI front panels, CPCI front panels, compact PCI ejector handles, PMC panels and PMC bezels
    Hope this helps,
    Iron-Man
    Mar 2007
    2083
    Hi Mark ,
    is this link any help ?
    http://docs-europe.electrocomponents...6b80847bed.pdf
    John
  1. 3D Furniture Cutouts
    By TheWorkshopGuy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-17-2011, 06:17 PM
  2. Bit for Cutouts in Plastic Enclosures
    By gpraceman in forum Want To Buy...Need help!
    Last Post: 06-23-2010, 04:23 PM
  3. Need some cutouts done in HPD plastic 1/16 thick
    By turboless in forum Employment Opportunity
    Last Post: 10-30-2009, 08:13 PM
  4. milling square cutouts in a panel?
    By PGale in forum MetalWork Discussion
    Last Post: 05-12-2008, 05:24 PM
  5. letter cutouts
    By AndrewB in forum Autodesk
    Last Post: 01-12-2008, 06:48 AM
