587,006 active members*
3,067 visitors online*
Results 1 to 11 of 11
    Jul 2005
    179
    Spindle alignment
    Have a Tornado 200 and did a spindle alignment test cut on a 3" dia piece today. Got 2.953 on the far side and 2.950 on the chuck side. Cut was 5" long and got .003" run out. I don't have a manual that describes the adjutment procedure but I did pull the front cover off and found 2 sets of bolts on the motor end, the other side of the spindle block has the interior cover attatched to it. Is this a jacking bolt adjustment or a shim adjustment?
    H
    Jul 2005
    179
    OK, got to this point
    There are two allen head set screws on the lower left front of the spindle base as seen in the top picture. In the manual on the base frame is shows an "adjusting block" in this area on the frame. There is a gap between the spindle casting and frame casting under these screws. I took the left screw out and it has a machined end on it. There are two allen head bolts on each corner of the spindle casting and the spindle is belt driven.
    It's taken a while to get to this point and apparently I'm going to have to put the chuck back on to make another test cut after any adjustments. Unfortunatley, the covers will not go back on the machine with the chuck in place, and you can't get to the base bolts with out the cover removed.
    1. Should the drive motor be loosened up to make any base adjustments?
    2. Shifting the spindle base on its mounting pad does not make a perpendicular move with the X axis. How to you take out a taper unless you have a jacking bolt or shim the spindle?
    :drowning:
    H
    Hi HMC710
    1. Yes, the drive belt does need to be loosened off before adjusting the head.
    2. Cut and test to get the desired parallel tolerance for the amount of tool pressure you will be applying when taking your usual finishing cut. The bigger the cut the more push off. Use the 2 allen screws bottom left of the headstock to pivot the head and remove any unwanted taper from the finished turning. One of the allen screws pushes and the other pulls the headstock to move it around the pivot. A tip is to leave a little nip on the bolts top right where the pivot pin resides, slacken off all the other bolts.
    Jul 2005
    179
    Pivot Pin
    Thanks 600,
    Pivot pin is located upper right then?
    Just got the chuck back on and getting ready to dial it in so I can make a cut. (then take it all back off so I can put the panels back on.......)
    H
    Quote Originally Posted by hmc710 View Post
    Thanks 600,
    H
    That is correct. As you look at it from the front of the machine.
    May 2006
    82
    Hi H !
    do you have this job done ?
    Jul 2005
    179
    Hey cncatj! How are things down South? Almost done, lined it all up with a few tenths of taper in 5". Pulled the chuck back off cleaned all the gunk off guards up and put them back on the other night. Now its just truing up the chuck again. I played around with different distances that the hydraulic jaw actuator was screwed on, I lost some travel the first time I put it back on. I was hoping to get it all done yesterday but spent all day doing eng drawings and cutting parts on the table. Once I get the chuck dialed in I'll clean up the guards with some 409 and check all my offsets. Then its on to tail stock alignment......:banana:
    A big thanks to all the help out there in cnczone land!
    H
    May 2006
    82
    Things are quite good Here H !
    It's good to hear that your machine is almost finished ,
    I'm now taking a turret all apart !!
    Puting all new Orings & seals
    Jul 2005
    179
    Good luck with that, I'm hoping I won't have to do that anytime soon. Got tailstock aligned and cut true for a few pcs then got some taper back. Changed out my cutting insert and will try another cut. Is there an adjustment on the hydraulic pressure on the turret? Mine seems to slam hard into position, I'm just not that much in a hurry. Also can the coolant flow be adjusted down?
    H
    May 2006
    82
    Sorry for the delay H ,
    About your turret issues , The slam in my opinion can be caused by several reasons:
    1-The shock absorbers , Does the turret slams in both directions ?
    2- Not enough lubricant inside the turret ,Duplomatic suggest a special type of lubricant
    also about the coolant flow , I'm not sure if the flow can be adjusted down ,
    by simply rotate the coolnt disc , H , P.M your email adress
    Jul 2005
    179
    I've only seen the turret go one direction. Shock absorbers? Will check into the lube. My turret has drilled balls where the coolant comes out. PIA to adjust or control. PM sent.
    H
  1. Spindle alignment
    By fastpcuser in forum Momus Design CNC plans
    Last Post: 05-27-2011, 03:15 PM
  2. Need Help with Spindle alignment!
    By Darian S in forum DIY CNC Router Table Machines
    Last Post: 10-26-2010, 03:04 AM
  3. Spindle Alignment
    By forrest39 in forum Benchtop Machines
    Last Post: 08-03-2010, 11:36 PM
  4. Toolchanger/Spindle Alignment
    By lovell110 in forum Haas Mills
    Last Post: 06-15-2007, 12:26 AM
  5. Spindle is out of Alignment
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2007, 04:32 PM
