586,069 active members*
3,402 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Sinpo DRO? - Need a Cheap DRO for a Bridgeport Mill - Need Advice
    Jan 2009
    65
    Hey guys, I bought a Bridgeport mill. It's a series I with the smaller 9x32 table size. I'm looking for an accurate Digital Readout on the cheap, however I still want it to work well, be accurate and repeatable, otherwise what's the point?!
    So far I seem to have two choices, either the chinese scales that are similar to a calipers, or the chinese glass scales. It appears that the glass scales are slightly more accurate, but cost more.
    I would also like to be able to view the readings without having to look at the little scale on the slide.
    So far, I I'm looking at this one:
    SINPO 3 AXIS DIGITAL READOUT DRO MILL KIT GLASS SCALE - eBay (item 260781055142 end time Jun-06-11 20:07:15 PDT)
    Does anyone have any experience with the Sinpo DRO's?
    Would this be worth spending the extra money over the caliper type?
    Thanks!
    Apr 2004
    105
    DRO Bridgeport
    Hello,
    I purchased my 3 axis DRO for my Bridgeport from JJ at -
    SINPO 3- axis digital readout (complete DRO kit) | eBay
    Great service, communication and delivery through DHL. Installed without any problems however I made up my own mountings. Liked it so much I bought a second unit for my Hipower Lathe.
    Cam
    Attached Thumbnails Attached Thumbnails P7220003.jpg   P7220004.jpg   P7220006.jpg   P7220005.jpg
    Jan 2009
    65
    Thanks Me2, I actually found a different listing that sells Sinpo that appears to have reasonable mounts as well. What do you think about the mounts in this auction?
    SINPO 3 axis Milling Mill DRO + 3 Scale + shipping | eBay
    Apr 2004
    105
    G'Day Firestorm,
    Yep, almost the same package as I got, mounts, shims fasteners etc. As I mentioned I manufactured my own mounts to suit my application. The mounts you get supplied are generic and can be modified to suit but I found it a much neater arrangement to make my own.
    Cam
  1. Bridgeport plasma on the cheap
    By Ubatoid in forum Videos
    Last Post: 12-11-2010, 06:32 PM
  2. Cheap CAM for Bridgeport Interact 1 MKII TNC155
    By Duncs in forum Uncategorised CAM Discussion
    Last Post: 09-03-2008, 10:08 AM
  3. Please help - Advice for evaluating a used Bridgeport Mill to buy
    By jkujawa in forum Uncategorised MetalWorking Machines
    Last Post: 10-26-2006, 02:20 AM
  4. Advice on Bridgeport BPJ to CNC
    By ToMMY2ooo in forum Bridgeport / Hardinge Mills
    Last Post: 09-14-2005, 09:54 PM
  5. Cheap 0 Clifton and servo drive selection (advice needed)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 04:21 PM
