I get this black gummy buildup on the bearings and the CRS rails.. I'm not sure what it is, but it appeared immediately when I started manually running the bearing carriages back and forth on the rails... So I think it's some sort of dirt inherent top the manufacture and shipping of the rails themselves..
As I clean it, it seems to take longer to appear.. but still does..
a) what is it?
b) is there a 'cleaner' I can wipe or spray on the bearings and rails to remove it? Some of the bearings (and even a section of rail) is hard to get to clean... So something that I could 'spray' on them, that would dissolve this black gunk, and then dissolve after I wiped them would be the hot ticket, if such exists.. I was tempted to use WD40 or goof off, but I thought it better I ask first... better dumb questions, than dumber mistakes...
Mark
