Anyone know how to get in touch with Nelson in Toronto that used to work for the Sodick dealer? I need some help setting up the network connections for a couple of linear machines.
John
John
what type of network issues are you having on the linears? The office forwards me most of the non standard networking issues so i may be of some help.
Hi, hello
I'm sanjaya, I've a problem with sodick edm nf II 80.
If I push the START switch, at the monitor appear message " the fluid temperature is too high"... so, after that the machine doesn't spark.
Can you help me, explain that. Thankyou.
Sanjaya.
I dont know much about the Nero Fuzzy machines but that alarm sounds like you have a problem with the chiller system on the machine. I would look for a temp prob on the work tank and see if the cable is broken. Does the chiller unit stay running all of the time? When the chiller is running can you feel a difference in temperature between the intake port and exhaust port on the chiller?
Ok, thanks.
I'll soon see to check on its port.
Thankyou.
