First off, has anyone though of an ATC that's actually a router changer?. I mean, instead of changing bits or having two routers/spindles on the axis at the same time, to just have some way to change between 2 or 3 routers (might be identical, might be not), for cases when you won't need any more tools (roughing and finishing, for example). Maybe it could be done by using a variety. home-made spindles (like those compact spindes some people have done on a lathe). The router mount/holder would firmly attach each router at tool change, or maybe just scrap that and add a router carrousel!
The second idea is something an uncle came out with when I was talking with him about how to sound isolate my machine. He said, most certainly joking: "Why don't you suround it with vacuum walls?".
Imagine a 2x2x2 mts room which walls, floor and ceiling have, say, 5 or 10mm vacuum-empty space between layers, and just a few posts (of carefully choiced material) to hold the inner room walls (no "flying rooms" here), a door mechanism, and holes for wires to go through. Has anyone actually considered such an extreme approach for their DIY machines?.
I'm not considering doing any of the above projects; it's just something that I wanted to share with you and know what you think about it. I'm pretty sure one or both of those ideas must have been approached somehow, somewhere by someone, DIY or not; maybe someone on the Zone has info about it?
