586,616 active members*
2,558 visitors online*
Results 1 to 6 of 6
    Mar 2011
    215
    Tool change alarm?
    Is it possible to have an alarm go off when its time to change the tool?
    My CNC is in my garage and I it's impossible to know when its time to change the bit.
    I'm using a TB6560 4 axis board and Mach 3. Is this possible?
    Mar 2011
    215
    Well, from the lack of responses I'm assuming that it is not possible. Bummer...
    Jan 2011
    27
    Yes it's possible. I'm using mach 3 and at the end of each file, I send the x axis home which causes the gantry to activate a mechanical rocker switch that turns off the router and dust collector. It could also set off an alarm to alert you. My shop is small and I hear the router stop so I don't need an alarm.
    Mar 2011
    215
    Wow, that is a great idea! But now that you mention it, I can probably get this to work off of the spindle relay.
    Thanks for the reply cr2.
    35538
    You can modify the M6 macro's to turn on an output during a tool change.
    Mar 2011
    215
    Cool, but I would have to get a breakout board or something right?
    I'm not sure how to get the output to do what I need it to do. I'm pretty much a noob at all of this. Especially when it comes to the macros. I don't know the language.
  1. Alarm during Tool Change on Bridgeport 320H
    By ChrisB in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2014, 03:49 PM
  2. EC500 tool change alarm
    By parkerdog in forum Haas Mills
    Last Post: 10-25-2010, 04:24 PM
  3. High speed tool change alarm
    By tkelly in forum Haas Mills
    Last Post: 07-31-2009, 06:23 AM
  4. Y over trave alarm on tool change?
    By automizer in forum Haas Mills
    Last Post: 06-06-2008, 01:49 PM
  5. Replies: 1
    Last Post: 07-31-2006, 06:19 PM
