Re: Water cooled Chinese spindle disassembly
Hi
I put the angular bearings opposing each other and you have to get the correct tension once warmed up, a bit trial and error,this will take out any vertical movement with the shaft.
I run for a long time cutting aluminum wood and steel with no problems but did stop with a burned out a coil. Never did find a reason, water or overheating it was just black.
Just bought a new spindle and move the changes over and still running it.
Russell
www.vapourforge.com ..................I recycle electrons.
