586,069 active members*
3,501 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Preliminary electrical schematics
    Mar 2008
    38
    Hello all. Ive drawn up some prelim schematics.They are rough....i mean rough lol. I just want to check if im on the right path or not. If you see anything that wont work or is simpler please dont hesitate to tell me, im still learning.
    Wade
    Attached Files Attached Files
    24221
    Normally you would see a contactor in the VFD feed and also on the primary side of any servo transformer, these together with the motor contactors would be dropped out via a hardwired E-Stop.
    The power supply for the coils for these contactors would be fed through a contact on the E-stop or Control relay.
    Also if any PLC is used, the power to the outputs is dropped out via the same relay, the inputs and any controller can stay energized.
    Al.
    Albert E.
    Mar 2008
    38
    Thanks Al. I was looking over some drawings of e-stop switches because i have 3 to put in.They looked like they were in the controller/relay circuits like you were stating. Would there not be an actual power disconnect to get a category 0 Emergency stop, Or would have all the contactors kick off be good enough?
    If there is a contactor on the VFD....is it energized when ever the spindles are energized or is it energized once and the controls for it then are used?
    thanks
    wade
    24221
    VFD's have low level logic inputs for fwd/rev etc. and generally the contactor is enabled and stays picked up with the E-stop relay.
    Now in a typical commercial machine the control voltage is 24vdc, If you set up a dedicated E-stop series string the 24v relay contact would switch supply to the contactor coils.
    The NFPA79 usually has some typical schematics you can use for a guide.
    Al.
    Albert E.
  1. Need Mits DWC-90-H Electrical schematics
    By chrisbraye in forum EDM Discussion General Topics
    Last Post: 05-31-2011, 04:20 PM
  2. Replies: 8
    Last Post: 10-31-2010, 01:24 AM
  3. Preliminary Outline of my First Table
    By lost_cause in forum Waterjet General Topics
    Last Post: 05-11-2010, 12:05 AM
  4. Preliminary G201X Manual
    By CoAMarcus in forum Gecko Drives
    Last Post: 01-20-2010, 08:50 PM
  5. mori sl-1 lx-1 electrical schematics
    By machineryaxis in forum Mori Seiki lathes
    Last Post: 08-10-2009, 03:31 PM
