586,108 active members*
3,175 visitors online*
    May 2011
    53
    Haas Controller?
    Hi to you all, my first post here so go easy on a newbie
    I have recently joined a new company and they are looking at purchasing a new Haas VF3 VMC. Could someone tell me a little about the controller on this model?
    I worked a VF1 about 7 years ago and that had a fanuc controller on it using pure g code programming which I enjoyed. For the past 7 years I have been running XYZ VMC's with Siemens Shopmill 810D Controllers which was more like conversational, inputting values into selected cycles. I have also been using OneCNC CAM System on the XYZ which was great for high speed machining, 8000 RPM 25mm DOC and 4000mm/min feed on some of the aluminium components we used to make.
    I have been told I will be getting 2 days training with Haas and then 1 day when the machine arrives.
    Just wondering what to expect with the new Haas.
    Many thanks
    Jul 2010
    Overall , they are good machines. The haas controller is basically fanuc style with a few nice improvements. Ask the trainer about programming from dxf files, program restart settings, and the hsm trial period(200 hours, I think). The book that comes with them is very good on explanations. My only problem with them is the tool change time and relatively slow rapids. Training should be after the machine is there and functional. I would not schedule it before.
    Apr 2010
    200
    The Haas will run with the same ISO G-Code that is used in Fanuc controls. The only thing I've found different is in tapping cycles for a Haas (I think it was an M29 in there for the Fanuc controller).
    Aside from that, the controller itself is much more user friendly and quicker to get around in. Editing is quicker and easier.
    Apparently I don't know anything, so please verify my suggestions with my wife.
  1. HAAS VF1 post controller
    By burton564 in forum CamWorks
    Last Post: 10-10-2017, 12:51 PM
  2. Haas vs. Fanuc controller
    By bmac30 in forum Haas Mills
    Last Post: 06-23-2011, 11:55 PM
  3. Haas Controller Shortcuts
    By plastibob in forum Haas Mills
    Last Post: 02-04-2010, 05:02 PM
  4. HAAS CONTROLLER LAG
    By ZERO260 in forum Haas Mills
    Last Post: 12-16-2008, 04:24 PM
  5. Newest Haas Controller
    By MegaMill in forum Community Club House
    Last Post: 08-17-2008, 09:26 PM
