586,111 active members*
3,202 visitors online*
    May 2007
    TL-2 IPS Canned Cycle
    Hello and thanks in advance for any help.
    I am new to CNC turning. I have been getting use to the control on the TL-2 in particular the IPS quick programing layer.
    I have been able to setup the tools and the offsets and use the canned operations. I have one problem that is driving me nuts.
    When I setup an OD turning cycle, for example:
    start diameter: 2.000
    Final diameter: 1.75
    Depth of cut: .010
    Feed: .005
    The cut always starts about .050 larger than the start diameter. So in the example above the canned cycle would start and progress like this:
    X= 2.050
    X= 2.040
    X= 2.030
    X= 2.020
    X= 2.010
    X= 2.000
    X= 1.990 (finally removing stock)
    The final diameter turns out fine.
    I cannot figure out where the "boy now that was stupid" ah ah answer is.
    Please Help
    Oct 2010
    121
    could it be that you are using very small cuts? 0.010 is very small. Try 0.040 cuts and see what happens. Mine does the same. I think the machine allows itself a clearance so wont start at the "start diameter"
  1. Turning 17-4 PH?
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 12-18-2014, 01:56 PM
  2. RFQ: PVC Rod turning
    By dandy7200 in forum RFQ (Request for Quote)
    Last Post: 05-01-2011, 09:08 PM
  3. Pinch turning or Balanced turning
    By pradeep in forum Mori Seiki lathes
    Last Post: 09-07-2010, 07:55 PM
  4. RFQ turning job
    By fastolds in forum Employment Opportunity
    Last Post: 12-15-2009, 06:28 PM
  5. Turning
    By camtd in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-01-2007, 06:40 PM
