586,047 active members*
3,639 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Exceeding servo drive power rating
    May 2004
    5
    Hello,
    I have a 100W brushless servo drive (technosoft motion controller), and I would like to drive a 200W brushless servo (servodisc). Both the motor and the drive run on 24VDC, but the drive puts out 5A, and I need 10A or more. If I don't need full performance, will just hooking the motor up work without trouble? Or, will the low impedance load burn up my drive? I've also considered an external push-pull emitter follower transistor network on the output of my drive.
    Thanks!
    Sep 2010
    1765
    ur scenario will work fine, just limit the motor capability. assuming it is a decently designed drive it should be fine. absolutely NO issue with inductance etc u mention.
  1. Power supply voltage exceeding 160V
    By ikke1983 in forum CNC Machine Related Electronics
    Last Post: 05-12-2011, 05:14 PM
  2. DISabling servo drive power on a DX/SX system
    By wjr09 in forum Bridgeport / Hardinge Mills
    Last Post: 10-11-2010, 04:16 AM
  3. servo alarm 51(current command exceeding) on mits m50l
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-05-2008, 02:06 PM
  4. servo alarm 51(current command exceeding) on Lynx.
    By Chuck Reamer in forum Daewoo/Doosan
    Last Post: 02-01-2008, 12:11 AM
  5. power supply sizing vs. servo rating
    By Erick Davidson in forum CNC Machine Related Electronics
    Last Post: 06-06-2006, 09:08 PM
