found this one HK-3026-880KV Scorpion Brushless Motor For Protos
just to give you a rough idea on whats out there.
Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 26.0 mm (1.024 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 10
Motor Wind ............................................ 10 Turn Delta
Motor Wire ..................... 14-Strand 0.25mm (30 AWG)
Motor Kv ............................................. 880 RPM / Volt
No-Load Current (Io) ................... 2.30Amps @ 6 volts
Motor Resistance (Rm) ............................. 0.026 Ohms
Max Continuous Current ............................... 52 Amps
Max Continuous Power .............................. 1450 Watts
Weight ......................................... 199 Grams (7.02oz)
Outside Diameter .......................... 37.5 mm (1.476 in)
Shaft Diameter ............................. 5.00 mm (0.197 in)
Body Length ................................. 48.4 mm (1.906 in)
Overall Shaft Length ...................... 74.2 mm (2.921 in)
