586,103 active members*
3,468 visitors online*
    Jun 2011
    Question double ball nut assembly
    so i recently posted a thread about how to pack a ball nut but now i need help putting a double ball nut together. i have no idea how to put the two nuts together if somebody could give me a guide it would be helpfull. also i will be posting pics.
    Jun 2011
    so my problem basically is when i pack the second nut, it gets very difficult to turn. is there something im missing or is there a specific way to do this
    Attached Thumbnails Attached Thumbnails Photo_F73BDC06-EED9-597C-8A92-CC812BF85D16.jpg   Photo_4B1C6C6D-0099-27DD-F7C0-54B5BF1D3F1B.jpg   WP_000090.jpg   WP_000092.jpg
    Apr 2004
    5737
    The way I've done this
    Is to machine a block of steel that allowed both nuts to screw into it from opposite ends. I put a wave-washer in between to tension one against the other. That way I could regulate the preload, and reach a compromise between backlash and difficulty in turning.
    By jamming one nut up against the other the way you've done, you're at one extreme of tightness. You need to back them off a bit to make it easier to turn - that's the main reason to use ballscrews in the first place. But my nuts didn't nest into one another like yours do, which is why I had to make that block. You might try installing a wave washer (spring) in between your two nuts, and tightening it a little less, then using Loctite to keep them in that position. Here's a source for all things wave-spring: Smalley Steel Ring Co. Retaining Rings, Snap Rings and Wave Springs - Index
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Jun 2011
    i havent packed it yet, but is this too much space.
    Attached Thumbnails Attached Thumbnails Photo_0B338B48-1210-48AB-CB77-E8070D426672.jpg
  1. Good pics of double ball nut for zero backlash?
    By gearsoup in forum Linear and Rotary Motion
    Last Post: 09-18-2013, 05:56 PM
  2. NEED HELP IN BALL BEARING ASSEMBLY
    By keyancnc in forum Linear and Rotary Motion
    Last Post: 09-28-2010, 03:53 PM
  3. Anyone make z axis ball screw sub assembly
    By farley in forum DIY CNC Router Table Machines
    Last Post: 07-24-2008, 11:47 PM
  4. Double ball nut cam loose - Desperate for help!
    By wwendorf in forum Linear and Rotary Motion
    Last Post: 08-06-2007, 05:49 PM
