Hello. I'm an electrical engineer with CAD and programming experience. I'm finishing a homemade 3-axis CNC machine with control by EMC2. Everything going well. I don't have a spindle yet so I've made a hot-wire foam cutter attachment. It's mounted on the Z-axis with the wire parallel to the Y-axis.
I need some help in converting DXF to NGZ. Can members recommend -
- DXF to NGC conversion utility. (I can use Windows or Linux.)
- Explain how I specify that the cut path is in the XZ plane.
Many thanks.
