REDUCE WORKMANS COMP CLAIMS! REDUCES MACHINE OPERATOR INJURY! WORKS WITH ANY EXISTING 'ER' STYLE TOOL HOLDER!
GenSwiss has introduced the E Z R Swiss Clamp System for fast and positive ER collet nut clamping. The new E Z R system eliminates wrench slippage and losing clamping nuts in machine sump/chip bin, keeps machine operators hands clear of sharp tooling, prevents accidental breakage of expensive ID micro-tooling and permits achieving proper torque settings. The Swiss clamp nuts replace standard Mini-Nuts and can be tightened using standard box wrenches or 3/8” drive ratchet wrench with either the E Z R wrench adaptor or the E Z R torque adaptor designed for greater clearance areas. Both adaptors engage and lock to the clamping nut with a specialized cam system on the face to deliver positive torque to the nut while eliminating slipping on the wrench and ensuring the nut does not drop into the machine sump.The new E Z R system is packaged as a kit that includes (6) E Z R Swiss clamp nuts, (1) E Z R wrench adaptor, (1) E Z R torque nut adaptor, plus spanner wrench.
CLICK HERE FOR MORE INFORMATION
