http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Did you get the kinks(vibration) worked out of the belt drive?
I like what you did with the blind. I was thinking about trying to contain the chips to an area around the mill. I was thinking of using a round ring with a shower curtain on it to enclose the mill.
Checkout my new Tech Blog! http://xnaron.com
No, I've not got the vibration fixed. I need to have the pulleys redone. My mini lathe and my skills aren't up to the task to machine them with the necessary tolerances needed. I'll order a new pair. When I ordered mine, I order 1 metric and 1 Imperial. One came with set screw holes already drilled and tapped, but, for the life of me, I don't recall which one. Was going to look to see if I could just order the correct bore size for the motor to start with.
I'm looking at making a enclosure. I'm thinking of doing something like Hoss did with his Chip-Pan.. but, I think it's going to be extended out in the front by around 7.5, enough for the vice to be inside of the chip pan.. But, that greatly complicates it because then I'm dealing with compound angles if I want the coolant to flow back toward the base. That's all going to come later after I fixed the spindle and finish up the power draw bar though.
Connor
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
I didn't build mine for flood but I tweaked his chip pan idea a little and extended the front out a little but only low enough to clear the vise. If you put a slight angle on the shelf it could drain back into the pan. The biggest downside is you can't do a full spin with the chuck wrench.
mrballistic is working on a wider version of my chip tray.
Hoss
[ame=http://www.youtube.com/watch?v=LtbapQ1P8yQ&feature=plcp]G0704 chip tray build part 1 - YouTube[/ame]
Looks like it could handle flood to me.
I hadn't really thought about doing it like that.. Gives me a idea, Light you said, angle the shelf, but, it'll have a front edge and end caps too. Solves a few issues with my Y motor being front mounted.. I'll draw it up in Inventor later and see how it looks.
That was kind what I was thinking to begin with.. But, I was going to do compound angles to drain the coolant back into the metal chip pan..
Question Hoss, How much further back does your Y extension put the Column? I want to take that into consideration when I build this so that If/When I device to extend the Y for over-travel, my chip pan can be easily modified to accommodate it.
Okay, Here are a few renderings of a chip-pan concept. Tolerances are tight at the front stepper motor mount area because of the X limit switch. and like someone mentioned, you won't have full clearance for the vise handle.. But, I don't think that's a big deal. I think in order to install it, I will have to remove the stepper, and possibly the mount. I think the spacer block could stay in place.
Hey Guys, Question: I'm upgrading the bearings on my spindle. I managed to get the smaller bearing nut removed. The lower one is giving me issues. I want to verify that this is a standard Right Hand Threaded nut on the larger lower one.. Part of the issue is, I'm using a pin wrench I made.. and the pins are just #6 screws and they're bending before the nut gives.
Thanks, Connor
On post#-9 HERE You can see the proto spanner wrench and slight mod I did to get mine out. Yes its regular rt hand threads and I built a wrench similar as what you did with the same result of bent bolts. I ended up just getting the spanner wrench and modding the holes slightly to use it. I'm in Oregon if you're near you can just borrow mine.
SFL
I got it from the Cornwell tools guy that comes by my buddies machine shop. I'm sure Snapon or someone like that in your area will have it. Its made by proto(stanley) and is about 40 or 50 bucks. I hated buying it for a one time use, but it was money well spent for the bearing upgrade. Good luck.
SFL
Go to Sears, they have lots of spanner wrenches.
Hoss
Maybe even in the tools section of a good bicycle store. They used to use pin spanners of course now it is all splined.
A lazy man does it twice.
Alright, Anyone willing to loan a spanner wrench big enough to handle the lower nut? This is crazzy. I got the top one off using my home made one, but the bottom won't budge. The spanner's I see online are over $40-50 for one large enough for the bottom.. and I only need it for this bearing upgrade. I can't make one right now because my machine is in parts.. This is so freaking frustrating!!
you can always use a hammer and punch at an angle.
Hoss
