586,067 active members*
5,287 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > How to change color of solid .igs part
    Jul 2007
    42
    Talking How to change color of solid .igs part
    I know that is is easy but I brought a solid model in from .igs file....I want to change the color of this assembly and separate them. Is this possible? I think it was a SolidWorks file. Should I just sperate them in SolidWorks? Still would like to change the color of the solids I bring in? Thanks
    Feb 2009
    2143
    Pick the select tool (black arrow), and select the part. After you select the part, move the mouse off of the part, and right click. Choose Attributes, Color, and change the color.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Aug 2005
    300
    Color
    If you are using v24 you can go to the lower right hand corner of your screen and change the color then select the part, right click, select modify to current color and click ok. That should get you there.
    Ernie
    Jul 2007
    42
    Great thanks that worked. That was easy. Sorry I am new to BobCad. Now what about layers or levels? When I brought this part in MasterCam it separated all of the levels of this .igs. How do I get BobCad to do this? Looks like it is all on one layer. Thanks
    Jan 2007
    78
    Quote Originally Posted by stinkfist View Post
    Go here and download the Video lessons for V24.
    My new V24 videos ready for download - CAD/CAM Trainer
    The is a lesson called "Part Origin Setting Lesson" that deals with IGS import.
    Look at all the lessons, it will help you to get going.
    Jos
    Holland
  1. Change color of a surface?
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 01-12-2011, 05:58 AM
  2. change color
    By weirdharold in forum Mastercam
    Last Post: 02-07-2008, 04:00 PM
  3. Change screen color
    By jwknow in forum Haas Mills
    Last Post: 10-27-2007, 12:04 PM
  4. Can I change the color of lines and dimensions?
    By csdilligaf in forum GibbsCAM
    Last Post: 08-03-2007, 05:34 PM
