here is a part program, start, to crash...
/m90
g50 s2000
g94
n101 g0 x35. z35.
n102 t0909
/g97 s2000 m3
/m8
g0 x7.1743 (crash z never moved away, x drove right thru workpiece)
the program was started from the beginning, the position was about x24., z0 (its the wheel load position on this horizontal lathe), normally the x35. z35. moves the wheel back to the limits at about x25. and z18. (ballpark- varies by machine), for some reason, the slides never retracted from the load position, and it cleaned the chuck. its has happened a couple times before on other Okumas also. just before cycle start, the setup guy had ran a wheel, cycle finished, door opened, program reset, he went to manual, indexed the turret 1 station, changed a insert, indexed back to tool 9 went to re-run the part and BAM.
I dont see a g90 in there, but assume its modal/wouldnt change by indexing turret(incremental x+ wouldnt have moved that way anyhow)
I'm suggesting they move the tool inside the forging before starting the spindle from now on, but still...this shouldnt happen.
Same guy (very experienced setup/cam operator, never saw him wreck anything the last ten years - until these Okumas arrived.
He showed me a couple weeks ago a similar problem, but reverse- I didnt jot down the gcode, but it was basically mid program, call a tool, move x to 0, and (only about half the time) if started mid program it would move z and x right into the chuck on a line with only x commanded. starting from the beginning of program toolpath was totally different...I still cannot fathom how a line that says X could move Z also...and all 5 of these machines will do it...
I assume there must be some sort of a modal gcode that triggers geometry for the new tool to stack onto whatever was running when program was stopped or something like that, but wouldnt even know where to tell him to look...If I get a chance, I'll ask him to show me the x+z on x line thing again and post the code/check the current block/modal status (assume okuma has this page- I'm used to Fanuc...)
Just thought I'd toss the question out here with some okuma gurus- any help appreciated
