586,110 active members*
3,171 visitors online*
    Dec 2009
    80
    Serial communication
    Hi all!
    I´ve just bought a Moxa uport 1110 (usb to serial adapter) for communication with an old machine with a Fanuc 11M control. When I go to "port settings" from device manager I don´t have the "advanced" button under which I can disable "FIFO buffering", which I always have been told to do to prevent communication interference. The adapter is connected to a new laptop with Windows 7 64bit. I´ll appreciate any input...
    /Thomas
    Dec 2005
    504
    On the 1200 series the setting is in the multi-port properties rather than the com port properties. See the attached images. Maybe the 1100 is similar?
    Dec 2009
    80
    I will take a look if I have that menu in my computer when I´m back at work. Thank you!
    /Thomas
  1. 8025 GP,M,MS serial communication
    By midnightrambler in forum Fagor Automation
    Last Post: 04-23-2009, 06:10 AM
  2. FANUC 0-M serial communication standard
    By telefunken in forum Fanuc
    Last Post: 11-14-2008, 09:20 PM
  3. Maho 700 serial communication
    By breazr in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-08-2008, 06:59 PM
  4. serial port communication for a V2XT
    By k.mccue in forum Bridgeport / Hardinge Mills
    Last Post: 01-25-2006, 07:24 AM
  5. Serial vs. parallel communication
    By OCNC in forum CNC Machine Related Electronics
    Last Post: 10-20-2004, 11:53 PM
