586,036 active members*
4,083 visitors online*
Results 1 to 2 of 2
    Jun 2009
    135
    Spindle bearing suppliers
    Looking for precision spindle bearing suppliers, Thanks
    Mar 2006
    2712
    We are using GMN sealed precision angular contact bearings with great success. They are purchased thru Motion Industries.
    The reason for GMN, they provide SEALED A/C bearings. Also sealed A/C bearings in smaller sizes than others. Plus, fairly quick delivery. Last week, (2) pair of sealed A/C bearings overnight, from stock in Houston TX.
    Where possible, we use sealed, lubed-for-life bearings to avoid plumbing a lube system and to avoid lube dripping down from vertical spindles with leaky seals.
    Dick Z
    DZASTR
  1. Looking for ball bearing suppliers for my ballscrews
    By bob1112 in forum Linear and Rotary Motion
    Last Post: 01-29-2008, 04:13 PM
  2. SL-30 spindle bearing
    By CyberLung in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 02:59 AM
  3. spindle bearing?
    By ged in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2007, 02:22 AM
  4. Floating Engraver Spindle Suppliers ? ?
    By DSS in forum DIY CNC Router Table Machines
    Last Post: 07-04-2006, 06:48 AM
  5. Air Bearing Spindle
    By KBW in forum DIY CNC Router Table Machines
    Last Post: 11-11-2003, 03:44 PM
