586,036 active members*
3,604 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 412 W/ Heidenhain 151 control
    Sep 2005
    250
    I am getting 2 different error messages and i am not sure if they are related.
    1. Axis PSU Fault
    I get this error massage when I drop my spindle speed More that 100 rpm's at a time.
    2. ) Gross error position D
    This happens once in a while when moving the " Z " axis
    Ray
    Sep 2005
    250
    Axis PSU Fault ?
    Does anyone know what could be causing this ?
    Ray
    Re: Bridgeport Interact 412 W/ Heidenhain 151 control
    Check the machine control power supply voltage may be DC supply missed,
    Secondly error related axies break may be wire broken or DC supply missed
    Again Check machine power supply circuits
  1. Bridgeport Interact 412 Heidenhain 2500 control 4th Axis ?
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2014, 05:16 PM
  2. Bridgeport Interact 1 MK 2 Heidenhain 151
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2012, 05:07 AM
  3. bridgeport interact 1 mk2 with Heidenhain 2500 control,
    By General-Jumbo in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2012, 11:45 AM
  4. Bridgeport Interact 1 MK 2 Heidenhain 151
    Last Post: 11-30-2011, 11:35 PM
  5. Bridgeport interact 412 W/ Heidenhain 2500 control
    Last Post: 09-27-2008, 01:06 PM
