586,121 active members*
3,643 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM-3P Boot Error
Page 2 of 2 12
Results 21 to 37 of 37
  1. #21
    Jun 2011
    36
    Thanks BLoke!
    It really helped me out.
    now the Direction is Ok.
    one request more If you could provide me the DIP switches settings and Magic Codes applied on it. is there any possibility to shift it to a DOS based OLD 386 or 486 Computer
  2. #22
    Jun 2008
    1104
    Magic codes? What are these?
    Do you mean making the machine software run on a PC?
  3. #23
    Jun 2011
    36
    yes MAgic Codes = Enter ***** enter ( for me these are Magic Codes )
    yes is there any possibility to run the machine software in a PC
  4. #24
    Jun 2008
    1104
    The codes you have used are the only ones that apply to your machine. There are more for machines with toolchangers and leadscrew maps but they are bedmills.
    It's not possible to run the machine software on a PC. There was a version of it available many years ago but it needed a dongle.
  5. #25
    Jun 2011
    36
    Any Way Thank you very Much For your Helpful Assistance
    hope to see you cooperation in future too.
    Nice to meet you here.
    best regards
    Max
  6. #26
    Jun 2011
    36
    hi, I have New problem now.
    when I switch on the Machine, when I press the power button from the console it does not start the Machine.
    only DS1 and DS4 relay LED light blinks slightly on the relay board when press the button
    please guide what should I check and do.
    best regards
    Max
  7. #27
    Jun 2008
    1104
    Check the white plastic ribbon cable from the buttons to the front board in the console. It may have a bad track.
  8. #28
    Jun 2011
    36
    its not working man, have check the cable its okay. is there any thing else
  9. #29
    Jun 2008
    1104
    Next, check the air pressure switch round the back. Then check the overloads on the contactors.
  10. #30
    Jun 2011
    36
    I have Checked the Air Pressure Switch, Its working Fine.
    Where is Overload ??
  11. #31
    Jun 2008
    1104
    On the contactors in the left hand cabinet.
  12. #32
    Jun 2011
    36
    hi, I don't Know what Happened but It is working now. today when I switched On the power its working.
    any ways Thanks for the Help. But I am Still Curious that what is problematic on it
  13. #33
    Jun 2011
    36
    My machine is again having the same problem, the power button is not working again.
    may be there is a possibility that air is comming but, the air pressure switch is not working. how can i check that , where is that Air pressure Switch
    Bloke! I will really greatful pls help me out in this regard.
  14. #34
    Jun 2011
    36
    i have checked the power ratings of the main power supply
    the light Blue Wire from Right Hand side is not Giving the 24VDC out put.
    can This be the main Problem for not starting the Machine
    Rest all the Wires are giving out put
    white ---> Ground
    Red --Black ---110 AC
    Brown -------->+12 VDC
    Blue ---------->+24 VDC (no output )
    Orange ------->-12 VDC
    Gray ---------->Com
    Gray ---------->Com
    Gray ---------->Com
    Yellow --------> +5 VDC
    Any Help ?????
  15. #35
    Jun 2011
    36
    I took a Risk by removing the 24vdc wire and placing a temporary 24vdc 40Amp switching Power supply and than tryed it powering up it worked.
    Now I will try to repair the 24vdc power Supply
    Thanks for the Motivation of CNC Zone,
    and Bloke, Coz you are the real Instructor for me in this Forum
    Thanks Bloke
  16. #36
    Jun 2011
    36
    Now My Problem is That
    May Y-Axix is Probleming, It shows Error on " Error Detected on Y "
    I have changed the Y connector to X , Than the Error Shifted on X
    I concluded that MAy be the Fault is in Motor Or Encoder
    I Opened the Motor, And When I checked the Carbon Brushes were finished.
    Now I am trying To Replace it Carbon Brushes.
    Hope it will Resolve My Error
    Any Suggestion Would be Highly Appriciated
    Thanks And Regards
    Max
  17. #37
    Jun 2011
    36
    now I have Changed the carbon Brush of the Y motor, when I Power on the Machine it shows the Servo Fault
    Any Clue ???
    Assistance will be Highly Appriciated
Page 2 of 2 12
  1. Hurco bmc 40 wont boot to config screen
    By inventor30 in forum HURCO
    Last Post: 11-05-2011, 01:16 PM
  2. Replies: 0
    Last Post: 11-12-2009, 03:25 PM
  3. Hurco won't boot up
    By Dave Rothermel in forum HURCO
    Last Post: 09-29-2009, 11:00 AM
  4. A2100/NT boot error
    By kentsui in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-14-2008, 10:44 PM
  5. Hurco ATC error
    By openforbiz in forum HURCO
    Last Post: 11-05-2007, 04:19 PM
