586,077 active members*
3,720 visitors online*
Results 1 to 10 of 10
    Oct 2010
    Selecting the right laser
    I am currently doing research on Laser as we would like to convert a mechmate that was used for wood routing to a co2 laser cutting machine to cut fiberglass isolation panel used for ventilation duct.
    the isolation board range from 1/2 inch to 1 1/2 inch thick.
    anyone know good site or forum post that have documentation on laser and different requirement for material and tickness ?
    I had bad experience with Chinese equipment in the past and since this machine will be used heavily during the day we would like to have a laser that can witstand that amount of work.
    any recommendation ?
    Regards,
    You probably going to need around 500 watts to do this effectively , I would contact someone like Kern lasers for recommendations on what to get. It won't be cheap tho.
    Sep 2010
    528
    Quote Originally Posted by telah View Post
    Regards,
    I'm not sure if a laser is going to be the best answer for you. When you say fiberglass, are you refering to fibergalss panels?
    I have been cutting FRP flat stock on my router with a fibergalss bit and it has been working very well.
    Abrasive Type Plunge, Diamond Pattern, Plastic Cutting Router Bits -Toolstoday.com - Industrial Quality Router Bits
    Oct 2010
    this is the material we need to cut, I was expecting a high price already so money is not an issue.
    Ventilation | Duct Insulation | K-Flex Duct™ Liner - GlobalIndustrial.ca
    I will get in touch with Kern for recommendation, thank you for the help.
    Regards.
    Feb 2006
    34
    WE are a laser co. I would suggest that you take a sample to some one with a 50 to 100 watt laser, and get them to test cut it..
    Sep 2010
    528
    If that is the type of insulation I am used to seeing, a roller knife might be a good way to cut it.
    Will you be cutting organic shapes with a lot of curves, or mostly straight cuts with angles?
    Jan 2009
    68
    The product data sheet that you provided shows closed cell flexible elastomeric insulation. I believe that this is a foam rubber product like wetsuit material, not fiberglass.
    Not sure if there are any lasers that can cut fiberglass insulation and laser cutting elastomeric may really smell up the neighborhood for miles around.
    You may want to call the manufacturer and see what they recommend for cutting this. I would guess a CNC system with some sort of razor knife.
    Oct 2010
    after more research this is the exact product that machine would be use to cut.
    Knauf Sonic XP
    the 2 size used are the 2.0 PCF .5 inch and 1 inch
    this look a lot more easier to cut then the material i was thinking.
    by looking at the spec those are made of fiberglass.
    anyone have experience cutting similar material with a laser or recommendation, I looked at kern laser and they don't seem to be selling c02 laser tube but only fully working machine.
    Regards
    HEY,
    HOW MUCH WATTS DO YOU NEED OF THE CO2 LASER TUBE?
    Dec 2008
    1258
    I would not recommend laser for this application, you will find ultrasonic cutting to be far superior and lower cost.
    You could probably get by with an oscillating knife, or if you only need straight cuts a rotary solution would work but ultrasonic would provide the best capability and seal the edge.
    As a benefit the CNC system could be used for other tasks too, just exchange the head.
    Have a look at Multicam:
    CNC Knife - EZ Knife System - MultiCam - Products
    Zax.
  1. Help Selecting VFD
    By Jackal66 in forum Phase Converters
    Last Post: 04-25-2011, 03:12 PM
  2. Selecting a machine
    By BanduraMaker in forum Commercial CNC Wood Routers
    Last Post: 01-16-2011, 05:37 PM
  3. Need help selecting CNC
    By jachyra in forum Want To Buy...Need help!
    Last Post: 01-13-2008, 01:10 AM
  4. Need Help with selecting CAD/CAM & tooling...
    By kprice1658 in forum Tormach Personal CNC Mill
    Last Post: 06-28-2007, 06:37 PM
  5. Help me in selecting the motor
    By shaiqbashir in forum Stepper Motors / Drives
    Last Post: 04-14-2006, 06:30 PM
