Originally Posted by
jbcj
They moved my tm2p through a standard 7 ft garage door. Had to unbolt and set aside the stove burners, and loosen the large conduit (there is a clamp at each end) to the head so it would flop over. It just cleared.
I put a dual outswing man door behind the the mill in line with the control and my mill is 6 inches from wall. For maintenance. I open the door from the outside.
Sent from my SM-T310 using Tapatalk
That's could be a first!!! I like it. Just don't do any maintenance in a storm. And, don't let OSHA near the house, as they would probably write you up for blocking an escape route.
:cheers:
Mike
