Originally Posted by
fullingdale
Would like to hear the thoughts of others on the best way to get a clean cut on the edges of prespex ... I am getting mixed results, quite possibly down to the settings that I am using.
When I have used thicker perspex (6mm) I find that the cut is melting the perspex and it tends to pool a little under the cut, which is making the back edges a little messy. I did think that perhaps I would be getting a better result if I used something like blu-tac to lift the perspex off of the metal grill.
Do you find that you get better results from cutting the outline in a number of passes, or by hitting it in one go?
Similar, when I am working on thinner material (1mm) I am finding that the edges are getting a little scortched.
Any guidance, appreciated
