I appreciate Delw's input, but I disagree vehemently. I say do NOT run the machine with the taper pins in, ever. If you have a real crash, your 30 minute job will turn into days possibly, when you have to remove kinked pins from the holes aligning a misaligned turret. I absolutely never run with the pins in, in fact it is one of the first things i do when a new machine arrives. The pins are designed for quick alignment, NOT to stabilize whilst running. Most techies will tell you this. Realigning a turret is a job you should know and be comfortable with, think if it as a learning curve of something you'll have to do again and again.
Robert
The beaten path, is exclusively for beaten men.
