586,317 active members*
3,347 visitors online*
    Oct 2007
    67
    Fanuc 6T G01 command problem
    Hi!
    A vertical machine with Fanuc 6T controller stopped executing G01 command. Does not give any alarm or error.
    Plz advice....
    Feb 2006
    1792
    You are possibly using feed per revolution mode with spindle at rest. Do you see continuous green light on CYCLE START lamp?
    Does G00 work?
    Oct 2007
    67
    Other commands are running. Cycle start lamp is green.
    Oct 2007
    67
    Quote Originally Posted by hell_pk View Post
    G00 is also working
    Feb 2006
    1792
    Try G01 with G98 and an F-word (feed per minute): G98 G01 F_;
  1. Fanuc 0M command to clear the spindle??
    By Otterpaw in forum Fanuc
    Last Post: 04-01-2011, 06:10 AM
  2. problem with ,C command
    By cncozz in forum G-Code Programing
    Last Post: 07-02-2008, 05:23 PM
  3. Problem with the G70 command
    By markus314 in forum G-Code Programing
    Last Post: 06-23-2008, 07:25 PM
  4. fanuc OT controller skipe M00 command
    By suresh patil in forum Fanuc
    Last Post: 08-03-2007, 02:15 AM
  5. fanuc servo motor moving without command
    By mtech in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2003, 02:39 AM
