586,055 active members*
4,221 visitors online*
IndustryArena Forum > CAM Software > Vectric > Is VCarve Pro good for engraving small letters?
Results 1 to 8 of 8
    Sep 2010
    528
    I am looking into VCarve Pro. I just downloaded the trial version and the program seems to be everything the we need. It seems to be geared toward larger scale work. Is it good for engraving smaller lettering?
    I own a marine electronics business. We are expanding and adding services for our customers. We would like to be able to produce engraved helm panels and electrical panels. The lettering would typically be about 3/8" tall. There would also be line art of boats on some of the panels.
    I have attached a couple of pictures of the types of panels we would like to produce.
    Apr 2003
    312
    Vectric's V-CarvePro software is highly capable of what you require...! It has the ability to v-carve enclosed vector font types OR engrave single line fonts. The only issue is tooling. Most likely... for lettering at 3/8" you'll be using 30 or 60 deg (included angle) engraving bits for enclosed vector alphanumerics... and for the single line font engraving... something in the 0.0625" to 0.125" neighborhood for end mills... ballnose or otherwise.
    Hope that helps...
    Senna
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Sep 2010
    528
    Quote Originally Posted by Senna View Post
    Hope that helps...
    Senna
    That does help. I already have the tooling for engraving, I'm just looking for the right software. I think VCarve is the answer.
    Aug 2005
    597
    Hello jharvey407,
    Attached are some images from a customer project posted on the
    Vectric Forum which might be along similar lines to what you are
    looking to do with the CNC machine.
    See > Vectric Forum • View topic - Brass
    If you have any questions please let me know.
    Tony
    Jan 2007
    211
    Quote Originally Posted by jharvey407 View Post
    You are thinking correctly! One addition that I might suggest is a vacuum table to keep the work perfectly flat while you engrave. There are several different sizes available from different manufacturers.
    Aug 2004
    2849
    I wonder if VCarve can fit the letters to a curve?
    Paul
    Apr 2010
    Yes, it can. The feature is called "Wrap text along a curve".
    Aug 2005
    597
    Quote Originally Posted by ViperTX View Post
    Paul
    Hi Paul,
    There's a video tutorial showing this on the web site
    See Working with Text > Working with Text - Vectric Training
    Tony
  1. Letters Inverted When Engraving
    By b weever in forum Mastercam
    Last Post: 06-23-2011, 06:44 PM
  2. engraving letters on a diameter
    By cuyeyo in forum Mastercam
    Last Post: 06-17-2011, 05:09 PM
  3. Tiag and engraving how good?
    By arguepo in forum Taig Mills / Lathes
    Last Post: 03-04-2010, 06:17 PM
  4. Engraving Mirror Letters for Mold
    By Jilofalltrades in forum Fadal
    Last Post: 06-30-2009, 10:24 PM
  5. I need help engraving letters
    By cutter22 in forum Uncategorised CAD Discussion
    Last Post: 02-13-2009, 06:25 PM
