586,217 active members*
3,302 visitors online*
    Jun 2011
    HT20 TURRET ENCODER PROBLEM
    IHAVE A HITACHI SIEKI HT20 WITH A fanuc10TF control The turret indexing encoder Part Number IP112S105R is damaged and unrepairable. can anyone help with a new or second hand one or a damaged one that i can get the light receivers from.
    David.
    24221
    You should be able to sub it with another model/make.
    Is it a through hole or a shaft encoder?
    Al.
    Albert E.
    Jun 2011
    HT20 encoder
    IT is a 10 mm dia.shaft encoder but it is a special made for HITACHI seiki.
    12 position binery with 3 strobes. not shure what the strobes do, I think they slow the turret as it reaches its position.
  1. HELP - Kia 15 turret problem
    By 3bmachine in forum Hyundai Kia
    Last Post: 09-01-2011, 04:30 PM
  2. Turret problem after crash on Hitachi Seiki HT20-SII
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 07:56 PM
  3. Doosan S280 Turret rotary encoder
    By s_itzcovitz in forum Daewoo/Doosan
    Last Post: 10-09-2009, 12:05 PM
  4. Qt20hp Turret Rotary Encoder
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2007, 09:10 AM
  5. turret encoder
    By Karl_T in forum CamSoft Products
    Last Post: 12-08-2005, 07:09 PM
