Hi everyone,
Currently, I am fixing a Mondiale M-600 Turning CNC machine. The main problem i have encountered is that one of the EEPROM ICs is missing or more precisely damaged cause it was inserted in the wrong orientation when it was served a couple of years ago.
I have tried to start the controller while pressing "7"&"9" keys and completed the procedure. The IPL mode appeared again declaring that there is a problem described by the alarm:
"Servo rom test: error"
I cann't find a turn around solution for this problem since i do not find it in the maintenance manual, but i suspect it to has something to do with this EEPROM IC.
Kindly, can anyone help me by providing the full bunch of the EEPROM ICs found in this controller which i "Believe" they were programmed by the Machine manufacturer and not by FANUC?
Main Board: A16B-1010-0320/05A
IC location: 402
Thanks in advance.
Yazamo
