586,103 active members*
3,366 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > sunnen grinder lathe attachment or in block grinder?
    Jun 2005
    141
    Question sunnen grinder lathe attachment or in block grinder?
    hi guys hoping someone more experienced could offer me a quick answer on this. Here is what I know, it is a sunnen model KN, the seller doesn't know anymore about it
    at first thought just reading the name I first assumed it was one of the old in block grinders but after looking at these pictures a little more it looks different then any of the in block grinders I have seen and I was wondering if this one actual attaches to a lathe????????????
    The guy sure ain't giving it away but and before I spend the money guessing I figured I ask if it is a actual attachment for a lathe maybe it would be worth more to me .......... you know how it is when you need something it is worth a little extra $$ then actual worth..........and when you WANT something it is wroth even a little more $$$ ...lol
    I'm hoping one of you experienced people will jump in and take a look at these pictures and let me know
    Jan 2010
    485
    Don't have a clue on how it works, but, the name plate in the first photo says
    " Crankshaft grinder". I know back in the 1950/60 era they had machines that could grind a crank in the block to save an engine, is this one of those?
    Jun 2005
    141
    yes sorry I should have mentioned it was a crankshaft grinder.......... the ones I have seen for the in block grinders the main unit was always much smaller and this ones attachment arm seemed like it was more for a lathe attachment (which is what i am looking for) but i am not sure and can't find any more information online just hoping someone is familiar a with the unit
    Dec 2006
    839
    If it is automotive in nature I would post on the "Speed Talk.com" site. There is a lot of older guys there and most that hang around there are very involved with the machine work side of racing and repair. I may be remembering wrong but I guy I think is called Mad Bill that may know of alot of the older equipment, anyway someone over there will know.
    Jess
    Jun 2005
    141
    thanks I'll check over there also .
    I posted this on another machine forum as well an the general opinion is it must have been a in block grinder and not a lathe attachment so unfortunately it will not be any good to me, but tank ya'll for the replys
  1. building manuel surface grinder and a od grinder
    By toolsrule in forum Benchtop Machines
    Last Post: 12-02-2015, 11:20 AM
  2. Help with drill grinding attachment to Universal Grinder
    By simso in forum Toolgrinding / Toolgrinding Machines
    Last Post: 10-24-2011, 09:05 AM
  3. grinder mill lathe combo CNC
    By hesham morsy in forum Vertical Mill, Lathe Project Log
    Last Post: 04-13-2011, 05:53 AM
  4. Crankshaft grinder lathe attachment ??
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-01-2010, 09:34 PM
  5. Tool post grinder for haas TL series lathe
    By L.Kiefer in forum Haas Lathes
    Last Post: 11-15-2007, 10:39 PM
