586,100 active members*
3,089 visitors online*
Results 1 to 8 of 8
    Jun 2007
    44
    Help, NV5000 screen goes blank
    Mori NV5000 screen goes blank. Screen comes back on after shut it down and leave it for an hour and turn on it back on. Then suddenly screen goes blank. Replaced screen back light and ballast board. Still the same. All axis can be jogged with blank screen. Any suggestions?
    Feb 2009
    6028
    Is the LCD power save on? Should be in the timers screen on Maps.
    Jun 2007
    44
    Quote Originally Posted by underthetire View Post
    I have no idea of how to get to power save and screen timer.
    Feb 2009
    6028
    Should be under the settings page. I've pretty much been only on the new maps iv lately. If you can tell me the control type at the top of the screen, I might be able to help further. An nv could be a mapps2 or newer. If it has USB it's 3 or newer, no USB it will be mapps 2, if it's a new machine with a light grey/white color control panel it's a mapps4.
    Feb 2009
    6028
    Quote Originally Posted by CNCmakers View Post
    Mostly it is 5V power supply problem, you could check below steps:
    CNC controller blue screen
    Go away spammer! Mori does not use some Chinese cheap piece of crap. You obviously don't know how the mori control is set up, you probably have never seen one!
    Jun 2007
    44
    I found the Timer and Power Standby screen under Setting menu. Under Power Standby, screen saver timer and other timers are turned off, back light is set to high. When screen went blank I had to shut down the machine and reboot it in order the screen to reappear.
    Feb 2009
    6028
    Still need to know what Maps is on that thing to help any further.
    Jun 2007
    44
    Not sure. It shows MSG 501. It doesn't have usb. It has flash card slot. It is a 2002 machine.
  1. anilam G blank screen
    By erutter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-29-2011, 04:33 PM
  2. blank screen
    By GCOXII in forum Milltronics
    Last Post: 04-15-2011, 02:12 AM
  3. Fanuc 11M Blank Screen
    By samachinetrades in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2010, 05:43 AM
  4. Blank Screen
    By star-turn in forum European Club House
    Last Post: 07-29-2007, 06:54 PM
