586,358 active members*
3,531 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Problem starting spindle after tool change
    Nov 2007
    90
    When I spot drill a part and then do a tool change to drill it, the spindle does not start after the tool change. I ran other similar programs this morning spot drilling, drilling, then tapping and had no problems with the spindle starting.
    What have I got wrong here?
    (DRILL)
    N1T21M03
    N2G81Z-0.0875R.1F10.
    N3X1.0334Y-0.8264
    N4X4.2735Y-0.3125
    N5X4.9033Y-0.3125
    N6X5.0891Y-1.7989
    N7X4.4690Y-1.8765
    N8X0.7949Y-1.8618
    N9G80
    N10T22M06
    N11G73Z-0.3092K.150Q.050R.1F5.
    N12X1.0334Y-0.8264
    N13X4.2735Y-0.3125
    N14X4.9033Y-0.3125
    N15X5.0891Y-1.7989
    N16X4.4690Y-1.8765
    N17X0.7949Y-1.8618
    N18G80
    N19M30
    E
    I got tired of trying to figure it out and added an M03 after the tool change to get the job done.
    Thanks!
    Oct 2006
    106
    An M06 will always output an M05 to the interface, stopping the spindle. An M03/M04 is necessary after any tool change to restart the spindle.
    Nov 2007
    90
    Thanks!
    Could it be that G84 need no M3?
    I'm still running G84 with no M3 after an M6.
    Oct 2006
    106
    A G84 tap cycle issues an M code (either M03 or M04) to reverse the spindle at the bottom of the hole, after an M05 (as long as the M05 is not shut off by parameter). The spindle is reversed to the original direction at the reference plane (at the end of the cycle), once the tap has presumably left the part.
    Notice there isn't an M03 or M04 code issued at the start of the cycle. I would think you would want an M03 (or M04) with an S code (to set the spindle RPMs), after any tool change and before the G84 tapping cycle block.
  1. Tool Change Problem
    By mark029 in forum Fanuc
    Last Post: 03-28-2011, 11:59 AM
  2. bp vmc 760/22 tool change problem
    By laserh20 in forum Bridgeport / Hardinge Mills
    Last Post: 07-01-2010, 03:19 PM
  3. Tool change problem.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-12-2010, 11:46 AM
  4. Tool Change problem
    By mattpatt in forum Fanuc
    Last Post: 03-10-2009, 02:05 PM
  5. Spindle Orient problem at Tool change
    By chipsahoy in forum Fadal
    Last Post: 12-18-2006, 03:33 PM
