586,508 active members*
3,394 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-M on Komo VR-508 Display Corruption
Results 1 to 7 of 7
    Jul 2011
    We use a Komo VR-508 router with a Fanuc O-M control panel. Upon turning it on the other day instead of the standard start up sequence on the screen we only see corrupt characters. There is no error message to speak of, just a series of 1's and maybe G's.
    Please see the attached picture of the problem.
    If anyone can offer help I would much appreciate it.
    Gabe
    24223
    It appears to me you may have the memory corrupted, if you have all the parameters incl 900 options and timer values and any macros backed up or on file, you could try resetting the memory.
    This is by pushing Reset and Delete and then power up while holding these buttons on.
    All the above files need reloading afterwards.
    Al.
    Albert E.
    Jul 2011
    Thank you Al. I am searching through our books now to find these parameters.
    Gabe
    The bottom code looks like distorted binary. Which would indicate an NMIC error. Which basically means, there is a comms error between a drive and motor but could be any. If you think it might be, send me the lower row of digits, i have a decoder.
    If it is not binary then it could be FROM,SRAM, Mother Board, a whole host of things. Really you should Fanuc in.
    CNC Data Ltd
    www.cncdata.co.uk
    24223
    Quote Originally Posted by gwilkerson View Post
    Gabe
    In any event it is important to have a back up of these, without them the machine is just a hunk of steel!!.
    Al.
    Albert E.
    Jul 2011
    Thanks to your help the machine is back up. Iam inputing the parameters from our origina documentation right now.
    Al.
    I used to call them tea cosies. But i like hunk of steel
    CNC Data Ltd
    www.cncdata.co.uk
  1. Replies: 2
    Last Post: 02-24-2011, 08:22 PM
  2. Fanuc ot display
    By Sparkatron in forum Fanuc
    Last Post: 12-09-2010, 05:30 PM
  3. rpm display on fanuc 10m controller
    By skippyfix in forum Fanuc
    Last Post: 11-17-2008, 06:20 PM
  4. Fanuc 0i-TC Display Parameter
    By Hoonie in forum Fanuc
    Last Post: 05-20-2008, 07:44 PM
