586,113 active members*
3,235 visitors online*
Thread: Laser power
Results 1 to 10 of 10
    Dec 2010
    14
    Laser power
    Hi All,
    Just got my upgrade 100 watt tube and power supply, from Coletech but the power supply is not working.
    Can you run a 100 watt tube from a 60 watt power supply without doing any damage to the tube ?.
    Cheers
    Pete
    Pete,
    You won't damage the tube by trying but it is doubtful that the 60W psu has a high enough striking voltage for the longer 100W tube so it just may not work.
    Tweakie.
    CNC is only limited by our imagination.
    Check the fuse in your new power supply , it might just be that that is blown.
    Dec 2010
    14
    Thanks for the reply's, checked the fuse and it is OK.
    Cheers
    Pete
    Dec 2008
    1258
    The PSU may not be wired correctly, depending on your model the interlock and/or laser enable circuits need to be grounded or held at correct input.
    Zax.
    Dec 2010
    14
    Wired as per these instructions.
    Cheers
    Pete
    Attached Files Attached Files
    Jun 2009
    12
    HELLO
    ABOUT USING A 40W TUBE ON A 50W MACHINE?
    40 W TUBES ARE CONSIDERABLE CHEAPER THAN 50W
    Jul 2011
    You will find that some laser tubes that have a SEPERATE exciter / RF unit must be tuned (or matched) to each-other. Connecting un-matched RF unit and CO2 tube can damage the tube.
    If it is all one unit (RF and CO2 tube in the one package) usually it is only power supplies / mainboard / firmware required to upgrade. But it is very messy and you'll probably struggle with it. Trade in your old laser on a new one - my advice!
    Nov 2010
    787
    Quote Originally Posted by nick81 View Post
    Man, wake up!
    They are talking about CW glass lasers, not RRF lasers.
    CNC lasers, constructions, service
    Nov 2010
    787
    Man, wake up!
    They are talking about CW glass lasers, not RF lasers.
  1. PWM laser power
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-15-2011, 02:47 PM
  2. Laser Power
    By apeman88 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-02-2011, 06:40 AM
  3. CO2 Laser Power
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2010, 06:28 PM
  4. no power to laser?
    By KPBadger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-23-2009, 06:35 AM
  5. Cnc low power laser
    By bushmac in forum Community Club House
    Last Post: 01-31-2009, 07:15 PM
