586,108 active members*
3,084 visitors online*
    Jul 2011
    400
    Hercus mill and lathe
    I recently picked up a Hercus compumill and a compulathe. They are both missing the controllers but appear to have seen very little use. The hand scraping marks are still visible on the milling machine ways. The lathe is in a similar condition.
    My question is can anyone tell me the specs of the taper in the milling machine? I was told it was an ISO 30 spindle is that correct? If so is there an alternate tool holder that can be used. From what I have found so far the ISO 30 tool holders seem to be quite rare and very expensive.
    Thanks for any replies
    Oct 2009
    45
    Yes, the Mill uses ISO-30 tool holders.
    I have not tried this myself..., but you MAY be able to use BT30 or CAT30 holders, these are designed for pull-studs instead of a threaded draw bar, the taper should be the same and drive dogs will likely fit - you'll need to modify the draw bar to suit the threads where the pull-stud would normally be installed and it will need to be approx 1" longer as these holders are shorter to accomodate the pull-stud.
    Jul 2011
    400
    Thanks Dan:
    I appreciate the response. It has proven to be quite a challenge to find any specs on this machine. It seems incredibly well built for only having a half horsepower motor.
    I think I'll pick up a BT-30 toolholder and see if it fits. They seem easier to get and certainly less expensive.
    Now to decide whether or not to use the original servos.
    Going to be a long project
  1. Hercus Compulathe retrofit
    By macona in forum Vertical Mill, Lathe Project Log
    Last Post: 01-13-2011, 01:05 PM
  2. Hercus lathe
    By Paul in OK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2009, 02:36 PM
  3. Hercus Computurn
    By Doug Baker in forum Australia, New Zealand Club House
    Last Post: 04-16-2009, 04:45 AM
  4. Hercus V300 COMPUMILL DNC
    By Jonathon in forum DNC Problems and Solutions
    Last Post: 11-04-2008, 11:23 AM
