586,082 active members*
3,613 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Fanuc ROBOCUT Alpha-1B will not power on the control
    Jul 2008
    Fanuc ROBOCUT Alpha-1B will not power on the control. At first I could not turn the control off using the off button. Instead I used the main power switch to turn it off. Now the control will not power on. You can't even hear that click from the relay. Since I don't have the service manual I don't even know which relay it is? I do have 18V at the on switch. All fans are running and you can see that the drives and the control all have power. Pendent displays "ROM CHECK OK".
    Any help will be greatly appreciated.
    Jul 2008
    I found the problem. It was the relay on a board inside the PSU. It looks like it was stuck in the on position.
  1. Fanuc Robocut α-1iA 18iW Problem
    By Danijel in forum Fanuc
    Last Post: 02-17-2011, 04:52 PM
  2. Fanuc Robocut U-V Urgent help needed !!
    By George123 in forum Fanuc
    Last Post: 02-16-2011, 05:00 PM
  3. Replies: 2
    Last Post: 01-14-2011, 08:51 AM
  4. EDM Programming Basics - Fanuc Robocut
    By BlueChip in forum EDM Discussion General Topics
    Last Post: 02-23-2010, 09:42 PM
  5. FANUC robocut - user points ?
    By WEDDLETON in forum EDM Discussion General Topics
    Last Post: 03-04-2009, 02:34 AM
