586,072 active members*
4,559 visitors online*
Results 1 to 3 of 3
    Kcam not cutting arc's
    Hi
    I have just started to play around with Kcam and use autocad to do my drawings, when importing DXF Kcam will not cut the arc's just does a line is there anything I have to do to get the arc's cut either in Kcam setup or Autocad
    thanx John
    Jun 2012
    R12 DXF
    :cheers:Try using Acad drawing and save as an R12 DXF file.
    Jun 2013
    7
    I have the same problem, but use Turbo Cad 18 Platinum, I don't know how to save in R12 DXF.
  1. need help with kcam 4
    By cowboy1ht in forum Uncategorised CAM Discussion
    Last Post: 12-23-2010, 07:05 PM
  2. cutting large arc's
    By peterklos in forum DIY CNC Router Table Machines
    Last Post: 04-24-2010, 01:54 PM
  3. Kcam 4
    By mwestern in forum Uncategorised CAM Discussion
    Last Post: 09-10-2007, 02:15 PM
  4. KCam.ini
    By pminmo in forum Uncategorised CAM Discussion
    Last Post: 06-12-2004, 07:30 PM
