My Z Axis makes a nasty grinding sound when it rapids in the down direction..
I suspect that this might be the fact that the portion of the drive train that goes through the thrust washers, needle bearings, and main bearing block is threaded instead of smooth drill rod..
If I were to cut the screw back, and then use a coupler and a section of 1/2" drill rod, the extra coupling dimension would require that I rebuild the entire Z carriage, and I would also lose an inch or so of Z travel..
So what I'm wondering, is if there are suppliers of 1/2"-10 TPI 5 start screws out there that can provide the screw with the first two and a half or three inches of the screw 'un-machined'...
That way, I can just replace the screw as is, with the un-machined part traveling through the shaft nuts, thrust washers, needle bearings, and bearing block into my helical coupler..
The only other way I can think of solving this problem without completely rebuilding the Z carriage would be if there is some sort of small diameter coupling that can be used to couple the screw I have to some 1/2" drill Rod..
Or, maybe you guys have some better ideas?
Here's a picture or two of how it's currently configured... (I'm going to post a copy of this question in my build thread too)..
Mark
