I am retrofitting a 95 VF-2 with a Renishaw probe system. I am using a MP700 probe coupled with a OMM and MI12. So far I have it fully working. I needed to add a relay to the mix (inside the MI12) to allow the macro to detect to probe turning on or off with a skip input macro test. I would like to know how it is officially wired up with a wired tool setter and optical probe from Haas. Right now I use the error SSR to bypass the probe when its off so the tool setter still works. The tool setter is wired in series with the probe. The only flaw with this is when powering on the probe I need to disable the error SSR bypass to detect if the skip input changes. I do this by adding in a relay that breaks the circuit from the error SSR when the start signal is given. Then allows the macro to check if the probe has turned on or turned off. Trying to see if there is a better way that I am just not thinking of. I am almost sure they are not adding another relay to the OMI. Anyone have a diagram?
