586,061 active members*
4,534 visitors online*
Results 1 to 16 of 16
    Dec 2006
    310
    Fanuc 0M Series
    Dear Sir
    Good Morning to u all.
    In one of our HMCs, we were getting Battery Fault and also BAT was blinking on Screen
    a) We checked and found battery voltage to be alright
    b) Still we replaced Battery (1.5V X3 nos.) with new Set
    c) Taken out Memory PCB, checked, battery Voltage on PCB found alright (as u r aware, white connector from Battery is connected to this Memory A4 PCB)
    d) Taken complete backup and erased memory with Reset and Delete---- still BAT was blinking
    e) Memory PCB A16B-2201-010 replaced with similar PCB but we retained all EPROMs of Memory PCB of this Machine
    f) After Power ON, we did not get Battery Alarm and BAT was not blinking but we started getting error 998 ROM Parity OB1 that means EPROM located at OB1 slot was defective so OB1 (9046 001I replaced with 9040 001I as were not having 9046 001I)
    g) Now we are not getting error 998 but we are getting errors 446 : 4 axis Disconnect and Error 447 4 axis Digital Parameter
    This machine has 4th axis, which we are not using since last 2 years due to mechanical problems and around same time done necessary bypass in parameters to run the basic machine with 3 axes till recently and EPROM at OB1 9040 001I taken from another Fanuc 0M machine which has no 4th axis
    Please advice on how to bypass Error 446 and 447 ??????????
    Best Regards,
    M. Rishikesh
    Sep 2008
    138
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Sir
    Best Regards,
    M. Rishikesh
    Set 914.7 to 0
    Dec 2006
    310
    Fanuc 0M
    Greenery_fr
    Thanks for ur reply
    Presently 907 11011100
    913 10010010 and 914 11000000
    Then changed 907 to 11010100 and 914 to 0000000
    Now we are not getting any error after control ON and also B is not appearing on screen under Machine Position screen
    But if we move X,Y,Z or W (Magazine axis), we are getting SPC alarm for pulse coder disconnect for x,y,z and W error 339, 329, 359 etc
    Kindly advice why it is so ????????
    Best Regards,
    M. Rishikesh
    Sep 2008
    138
    Hi
    Hope it will help you
    Attached Files Attached Files
    Dec 2006
    310
    Fanuc 0M
    Hi Mr. Greenery
    Can u please give me ur email id?
    After I changed bit 907.3 and 914.7 to 0, no error related to B as B got completely bypassed but whichever axes (x,y,z w) is moved we get SPC error 3n9 for that particular axis
    As u know all SPC of all axes can not go bad at a time and there must be some common problem?
    We tried by replacing Axis control PCB where all the connectors from SPC of all axes get conected? with another ok machine, still same problem
    Reloaded all machine parameters.
    what else could be the reason sir for error 3n9 for all axes ???
    Kindly advice
    Best Regards,
    M. Rishikesh
    Sep 2008
    138
    Hi M. Rishikesh
    Are your motor alpha series. If your motors were alpha series. The servo software 9040 do not support alpha series
    Regards
    Greenery
    Dec 2006
    310
    Fanuc OM
    Hi Mr. Greenrey
    Thanks once again for such prompt response. As we have alpha drives and motors, 9040 might be causing error 3n9 for all axes, we will try to burn a blnk EPROM with another OK machine to see further.
    Please confirm if EPROMs in the order of FE1J, FC1J, FA1J, F81J, 201J are for memory in higher order ???????? and OE1 and OE2 are for PMC
    Best Regards,
    M. Rishikesh
    Sep 2008
    138
    Hi Mr. Greenrey
    Best Regards,
    M. Rishikesh
    Hi M.Rishikesh
    The OE1 and OE2 for PMC, can you take a picture of your Mem card with all chip pluged in ?
    Regards
    Greenery
    Apr 2013
    Unhappy fanuc Om
    Quote Originally Posted by greenery_fr View Post
    Hi
    dear Mr GF,
    I have a machine which use fanuc Om system, but today this machine lost parameter list so i have to set up one again, but after i restart, it show 447 4 asix digital parameter alarm, but this machine have only 3 asix. I dont know what to do, pls help me!
    Aug 2011
    2517
    a possible answer is in posts #2 and #3
    Jan 2007
    48
    I have a 9046 001I this eprom is the spindel sofware,
    Apr 2013
    how to setup fanucOM encoder to 0?
    Mar 2005
    816
    Slightly OT, but how does one change a 0M Model C to a 0MF??
    Jan 2007
    48
    wath means for you setup OM encoder to O. wats is your alarm specified?
    Jan 2007
    48
    upgrade the sofware locaded in men board
    Apr 2013
    Who can give me fanuc Om parameter list ? Please, i really need it
  1. Fanuc series 21i-mb
    By schmitty9 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-18-2012, 08:40 PM
  2. Help with Fanuc Series 0-M
    By accramachine in forum MetalWork Discussion
    Last Post: 10-25-2009, 11:50 PM
  3. Fanuc O-T Series B
    By yarpo in forum Fanuc
    Last Post: 09-24-2008, 12:13 PM
  4. GE FANUC SERIES 15M
    By rajesh_1355 in forum Fanuc
    Last Post: 06-10-2008, 11:59 PM
  5. Fanuc Series 10
    By kayleesdad in forum Fanuc
    Last Post: 05-09-2005, 08:30 PM
