586,062 active members*
4,405 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > file extension not being recognized
    Dec 2009
    28
    I am stumped here. I have a Mini Mill and just began using MasterCam. When I save my post to my floppy the control isnt recognizing the .nc format, which is what the machine definition says Haas uses. I get "File Not Found" If I hit f4 and check O08999 they are there but everything looks like this-
    (TEST NC 352310 7-04-11 13:16)
    (o00009 NC 352309 7-04-11 13:22)
    Before now I have been keeping an old file on the floppy and just hitting all and clicking on the old file that is recognized by the control to get the extension right for the new one. It doesnt show me the extension though and I would really like to know what format I should be using. Any help would be welcome.
    Rodney
    4826
    First, make sure that the small o is correctly typed as an upper case O.
    Do not put the program number within the parenthesis. The file name should be within parenthesis.
    If the file is called O00009.nc, your machine should see it. (Also working from memory here as I quit using floppies a long time ago.)
    But the file can have any (8 CHARACTER) name, with an .nc extension, so long as the first line is a % sign and the next line has the program number in proper format:
    O00009 (TEST)
    Dec 2009
    28
    Thanks for the response. I was thinking it should work too. Thats one of the wierd things. Top of post looks like this before being saved.
    O00009 (TEST)
    When i generate a list with f4 everything is in parentheses. If when saving to floppy I click on an old file and replace it it does fine so for now I will just keep doing that until I find a setting or something thats not right.
    Dec 2009
    28
    Well I just figured out if I dont click "save as" and just click the floppy symbol at the top of the page it doesnt put the .nc after the name and it works just fine. Over thinking MC got me again.
  1. 810D file extension
    By Steve.Gray in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-12-2014, 04:27 PM
  2. Daewoo File Extension Issue
    By Shack in forum Daewoo/Doosan
    Last Post: 09-28-2010, 06:15 PM
  3. Opening CDR file extension.
    By terry32506 in forum Uncategorised CAM Discussion
    Last Post: 03-02-2008, 05:53 PM
  4. File Extension Question
    By TZ250 in forum Milltronics
    Last Post: 08-06-2007, 02:55 AM
  5. post file extension
    By GRANDPA in forum Mastercam
    Last Post: 03-22-2007, 04:44 AM
