I was looking at a VFE and was wondering if it was a VF1 with extended travel or a VF2 with options. I did notice that even though it was a year 99 machine it had brush servos. What do people think about them? all our machines are brushless
www.machmachine.com
I think it was VF0E, a VF0 with extended X travel.
We have a couple of machines with brushed servos from the 1990s and both give good service. I know we replaced the Z drive on our 1995 HL1 a couple of years back but considering its age that was not surprising.
I bought a brush type VF1 in 1992. It went with my business when I sold it 9 years ago. It is still in operation at that business and it is 20 years old now.
I remember changing the brushes on the Z axis once, and blowing the dust out a few times.
No difference in operation, so I see no reason to pass up a brushed mill.
Mike
A VFE was a VF0 machine with no options at all. There was no floppy, no swarf auger, no Pcool.
Brushed axis motors just means that more maintenance will be needed - brushless motors run without maintenance - brushed motors need periodically stripping down and cleaning. To be honest you would be better off buying a machine with brushless motors.
Hope this helps
We have a VF-E with brushed servos, machine came with macros, rigid tapping, and an auger. Every time I read about these they come with something else, hah
I would love to find an explanation of all of the designators myself. I have never found one though.
VF1>, VFE, VFOE, TM>, etc.
Anyone have a real explanation chart.
Mike
I always thought that the "E" was designated for education. Seen many in trade schools. Could be extended since X seems to always be larger.
Here is a tentative list:
Mills:
VF=Standard Mill
VM=Mold-Making Mill
TM=Tool-Room Mill
OM=Office Mill
EC=Horizontal Mill
VS=Large Frame Vertical Mill
HS=Large Frame Horizontal Mill
UMC=Universal Machining Center (Exclude?)
E=Standard, no options
D=Direct Drive
B=Gear Box
P=Enclosure, until enclosure became standard
XT=Extended X axis
YT=Extended Y axis
ZT=Extended Z axis
YZT=Extended Y & Z axis
SS=Super-Speed
Lathes:
SL=Old Standard Lathe
ST=New Standard Lathe
TL=Tool-Room Lathe
TL-15,TL-25=SL with a sub-spindle
OL=Office Lathe
GT=Chucker Lathe
HPCL=Collet Lathe
DS=ST with a secondary spindle
W=Wide-Swing
B=Big-Bore
L=Long-bed
SS=Super-Speed
APL=Automatic Parts Loader
T=Tailstock
Ken Foulks
I can add one to the 'tentative list' because I have two of them.
HL= Really Old Standard Lathe
So you mean my "SuperSport" badging is a fake!!
So its a VF-EXT with 20x16x20
Im guessing this is a VF0 with the travel of the VF1
www.machmachine.com
I asked the same question a while back. I learned that Haas switched their VMC's to brushless servos beginning with the 1996 model year.
However, the VF-E produced in 1996 and some later years used the older style brushed servos which have lower rapid speeds. The "E" stands for economy because these machines sold new for less $$ due to the fact that they used the slower brushed servos. The travels are the same as a VF-0 or VF-1 (20x16x20) and as you've seen they could be ordered with options such as a chip auger, programmable coolant, etc. I don't know if it was available with a gearbox.
That's what I was told anyway and it appears to be accurate info according to the used VF-E's I've seen advertised.
It would be easy to confuse the VF-E with the VF-0E. The VF-0E is the same as a VF-0 (no gearbox) but the "E" in this case stands for extended X travel. The VF-0E has 30x16x20 travels.
Edit: Just read your last post. The VF-0 and the VF-1 have the same travels. The difference is the VF-0 doesn't have a gearbox and the VF-1 does. I'll just take a swag and say the VF-EXT is a VF-E with extended X travel (30x16x20) maybe? So brush servos with extra X travel.
