Greetings, all;
I'm planning to build a wood router table to sit next to the milling machine in my shop, and I'm doing some designing and collecting of useful parts.
I'd like to recycle and use the gantry I took off an old CMM system last week, since it's rather nice. It's made of steel tubing with some reinforcement, all welded. It's about three and a half feet wide and two feet high, which I want to put on a 6 foot table. It's in three pieces and bolts together with socket head cap screws through flanges.
I'm wondering about weight... the gantry weighs about 100 lbs empty, and I'll have to bolt on carriages, a drive mechanism, the Y/Z system, and the spindle, so probably something like 150-ish pounds when done.
It is really solid, rigid, and precision formed so I can basically skip gantry design and construction, plus it should be capable of handling a lot of force.
I'm planning on using a set of 5 phase steppers, 697 oz/in, for this machine. I'm suspecting I'd have to use a pair of them locked in step to move the gantry to avoid any racking. Or could I get by with one?
Probably the X axis would be geared 4:1 to move the gantry with belts.
Your thoughts?
Erik
