Originally Posted by
Brian P.
P.S
To get machine to run without having to hold the button go to settings. Type in 51 and cursor down. Hit the right cursor button. Off will change to on and blink. Hit the write button. Door hold overide is now active and you do not need to hold the button.
Unless you power Off then repeat the above process. this is the same as the Door Overide for a VF/HS MILL
My Bests,
Glenn Davis
General Manager
Engineering & Machining
Lacefield Plastic LLC
www.lacefieldplastics.com
1148 West 3050 South Unit D
Ogden, Utah 84401
(P) 801-394-4990
(F) 801-394-4247
