586,036 active members*
3,543 visitors online*
    Dec 2010
    1230
    CNC Enclosure Lining ???
    getting close to the enclosure build part of my conversion and looking for the best liner.
    plan is very similar to the one HOSS built and I'm in SoCal where all the good stuff like most epoxies and even hammerite can't be sold due to VOG levels.
    enclosure base will be plywood and I'm looking at either Rust-Oleum Garage Epoxy or my newly discovered contender Parkland Poly Wall.
    the garage floor kit will run and pool on the verticals, but with so much of it for $65 I can put a thick layer and should be okay. the poly wall seems perfect and a 4x8 sheet should be enough to waterjet out all the needed shapes then glue them in and caulk the seams and corners. price wise the poly will only be slightly more since I have to get adhesive and caulk.
    the info on the poly STRESSES the expansion and contraction and they need 1/8" gap between all seams and corners which makes me wonder how long it will hold up and stay water tight at the seams. my garage door is open 6-17 hours a day so it does get temp changes, but not terrible.
    anyone have any thoughts? anyone used poly wall?
    I just use shower lining material, worked great.
    Donald
    Nov 2009
    4415
    Why not have a metal pan built by your local ac or sheetmetal shop? Easy and watertight plus the shop will enjoy building something different.
    Dec 2010
    1230
    I really like the multi level design that promotes coolant flow. I think i am just going to go with the garage floor 2 part epoxy and make it easier.
    Mar 2010
    24
    I am planning on using fiberglass resin for mine. I would hope they have not banned fiberglass in California. Check your discount auto or whatever auto parts places you have.
  1. Lining pick off collet up with part
    By Q Special in forum CNC Swiss Screw Machines
    Last Post: 02-13-2010, 01:49 AM
  2. NM-135 enclosure???
    By fourwheeler in forum Novakon
    Last Post: 07-19-2009, 08:08 PM
  3. lining up the live tooling
    By Michael82 in forum Haas Lathes
    Last Post: 12-04-2007, 04:02 AM
  4. My new enclosure
    By David Da Costa in forum Commercial CNC Wood Routers
    Last Post: 10-28-2006, 06:03 PM
  5. Lining up a CNC mill to an existing bolt pattern?
    By youngfg in forum MetalWork Discussion
    Last Post: 11-07-2005, 09:05 PM
