My goal is to construct a machine that is capable of cutting out foam blocks to form the plugs for aircraft parts. I would like to be able to work on an area of 7' X 5' X 4'. This type of volume would be sufficient to produce molds for engine cowlings and leading edge D-tubes (in sections). I was inspired by what I saw at http://www.grabercars.com/content/view/67/2/. However, I feel that while the design is promising, it can be improved much upon.
My CNC expierence is limited to a 3 axis machine equiped with stepper motors. I have been reading what I could online and I feel I have formed a good idea of what the machine will look like. My main problem is there is too much information to digest. If anyone has any helpful advice or pointers, it will be much appreciated.
Description
The CNC is to be constructed out of 8020 Aluminum extrusion when at all possible. I have considered welding steel tube, but the 8020 leaves more flexibility.
The X axis is mounted on 8020 rails secured to the floor of my garage. The gantry rides on THK rails and the motion is to be provided by a ball screw on either side. Similarly the Y and Z azis are to move on a gantry constructed from 8020 and slide on THK rails with the motion provided by a ball screw.
What I am stumpped with is how to construct the swivel head. I have looked at dougherty drives, DoughtyDrive Products, but am a little put off by the price tag. Besides, I rather build one myself. I am considering constructing a head from Harmonic Drives off ebay, but I have no expierence with them or the servos they are usually powered by. Further more I have been using a milwalkee router and it is much larger then any other swivel head that I have seen. That brings up the question of a spindle.
Does anyone have any good swivel head ideas/ plans Sould I use servos or steppers. Finally would I need to get a fancy spindle for the head or can I get by on my hardware store router?
I have considered the CAM and CAD issue and can afford a good program. I also am looking at flash cam for the controller. Any assistance is much appreciated, I just need some direction.
